EvoIII vacum line
rksudrick
79
Jan 20, 2006
Roundlake Beach, Illinois
Ok, So I talked to a guy about my boost controler issue. He said The com side should be teed off between the wastegate and the turbo. I have a evoIII and I can't find where the vacum line is???? Is there one on this turbo?? and if not where does the wastegate line go to.. Thanks in advance...
wastegate line just goes to the intake manifold... which is where your BOV should be connted.. so just T off from there.
I bought the car with the profec B in it, He has the on side teed into the bov/intake and the wastegate directly to the com side. I don't think this is correct though.. Any ideas
You can hook it up anywhere after the turbo. There are sometimes ports on the intake, throttle body, compressor housing, J pipe, and upper IC pipe.
Best place is to hook it up to the wastegate and to the nipple on the j-pipe. But you are using an electronic controller so it may be different. Find the instructions on Greddy's page or another one and read up on it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
