evo8 fuel rail on 1g
90tsidude
Jan 12, 2007
Bethlehem, Pennsylvania
so i got a great deal on evo8 injectors on ebay. $86 shipped. when i got the package it was the whole fuel rail. it looks like it would work but wanted to double check due to FPR settings and such but could i just bolt the whole thing on my 1g? i don't know if the evo's FPR's hold more pressure and that would be a problem. as far as i searched no one has done it but figured the wisemen would know best. if it matters im running a walbro190. thanks in advance.
ok, would there be any reason that i should swap the FPRs if they are even interchangeable? thanks, im waiting for a nice day to swap the injectors then.
I've never seen a side by side comparison by my impression has always been that the evo FPR had approximately the same capabilities as a 2g FPR. The reason that Evos are better at handling larger fuel pumps is that they use a lower voltage supplied to the pump when they are not under load and a higher voltage to increase flow when more fuel is being consumed.
