2g Fuel rail on a 1g?
RED&BlackGSX
53
Mar 24, 2004
oklahoma city, Oklahoma
ok, im having FPR overrun with my 255 holley pump. It idles fine, would a 2g fuel rail and regulator fit a 1g?. Im thinking it will. I can get 2g fuel rails and regulators all over the place. and Yes ,I have already thought of a AFP-R, but that gives away the sleeper look. and YES, my fuel pump is probably a lil biggger than I need, but it was cheap and new, and works. any suggestions would be awsome
A 2g fuel rail/regulator does fit on a 1g, just installed one on a 1g the other day.
But it honestly would be more effective to get an adjustable fpr..
Matt
Ok..Thanks for the reply,so I assume the 2g FPR won't bolt up to a 1g rail?. Thats my main focus, if the 2g FPR will fit the 1g rail, there is no need to by a 2g rail. whats the diff?, 2g and 1g rails
I've put a 2g FPR on a 1g rail, but only because it was needed to make a quick fix
to get this to work you would need to slot the bolt holes, and if i remember correctly, it barely worked that way, again, it was only because we needed to get a car running fast that we even did it, I'd advise against it
Matt
