evo ecu high idle!
KingJamesEli
Jan 15, 2015
tacoma, Washington
Ok. So my last car I had came with a black box in It, I took that ecu out and put it in my current car with some 850s and tried to tune with tactrix, no matter what I did it idled 1500-2000 and very rich low 10s. Tonight I remembered that in my white car I couldn't get an idle under 1k and that was with this ecu in. Than after a few more moments I realized aren't the stock black boxes H4? Mine says H8. Is this an evo ecu? Maybe if it is I'll have to adjust ignition timing and re-scale my MAF (stock) And use evo injector scaling? Any help brothers?
Start with injector dead times for idle AFR tuning. If the richness persists at higher RPMs then start playing with the global scaling values.
I've tried 1500cc and 450dead time. I also just learned that my car is a 1996, And my ecu is from 1998
450 deadtime might be too high, have you tried a lower value?
Also, I'm not familiar with Tactrix but is there a way to see if the car is stuck in open loop? That might make it run rich as well.
No it's in srock settings for o2 loop modes and I've tried lower dead times. Nothing wants to work for some reason.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
