Evo 16G problems?
Musashi450
94
Jan 3, 2003
Champaign, Illinois
Hey guys,
ok so I'm in the process of rebuilding my motor and upgrading a TON of stuff around it. My question is concerning the evo iii turbo that I've bought for it. When me and a buddy were bolting it all together on the stand, we put the turbo on and he noticed that he can rotate the flapper door with his finger pretty easily. He was telling me I should shim the wastegate or bend the arm some to keep the flapper closed tighter. I'm curious as to how tight the door actually needs to be when the engine is just resting. Would the vaccum that the engine experiences normally cause it to go tight? The turbo is in good condition and I just puleed the actuator off to see if the arm was bent at all but its not? So why would I be able to do this?! Please help me cuz this is driving me crazy. Thanx a bunch guys.
Engine vacum is what is seen at the intake manifold. It has nothing to do with the wastegate flapper door.
Is he moving the wastegate flapper with the actuator arm attached ?(you have me confused there) If that flapper door doesn't stay closed properly, you'll never reach full boost or it will take forever and a day to get there. Your exhaust would be bypassed through the wastegate flapper instead of going through the turbine and spooling the turbocharger up. If you can move the actuator arm pretty easily, then you may need to replace the wastegate diaphragm. You shouldn't be able to move the arm by hand that easily, and when it's attached to the flapper that shouldn't be able to open until it sees enough boost pressure from your boost controller.
Sorry for my limited knowledge on the vaccum ;) It's not that the arm itself moves easily. I took the actuator off and tried pulling it myself and it was very hard. It seems that when everything is bolted up and the arm is pinned to the flapper, It isn't sealed all the way, but their seems to be no bend in the arm or the bracket. He is able to turn the flapper door with his finger. Not necessarily pull it open but spin it around. It doesn't seem to be contacting the wastegate opening. This is way I had brought up the suggestion that I've heard of shimming the bracket on the actuator so it would pull the arm back a bit, hence tighening the flapper.
