everything has power but no start
xxvikinwarrxx
Nov 26, 2005
philadelphia, New York
hey everyone im a newbie here and i was wondering if anyone can help.i have a 91 talon tsi i have just replaced the battery,starter,ecu and the alt and alt fuse.i was driving home one day and my car started to die out then quite running period.when i try to start it i get one click and that all.all my lights work and power windows.please help
It sounds like your alternator may have failed. I would check all the cables first and make sure nothings loose. Also, it is possible that the starter could of failed again.
A bad alternator will drain the battery until the car dies. Then you'll have a bad alternator and a dead battery.
I'd take both in and get them tested again.
Just because you bought something new, doesn't mean it's perfect. Always always always test what you can before you install it. I don't care if it's an alternator or plug wires. Test everything you can. It saves hours of headaches troubleshooting later.
thaks for the reply you guys. i just had a friend from autozone test my alt and my battery also the starter and there all good. i check everything i could think of,im lost:(
Check your Engine Coolant Temperature Sensor (ECT).
Make sure it's still plugged in and/or not damaged.
thanks alot for the help you guys i figured out the issue my timing belt was all missed up and it bent all of my vavles so i had to replace them and the pistons
