habitatguy187
- 3,648
- 262
- Aug 20, 2008
Indianapolis,
Indiana
My father-in-law needs his clutch changed in his 73' Cuda, he asked if I wanted to do it but I'm not sure if I want to take the risk since it's not my car. I tried finding some stuff online about doing it but didn't come up with anything. There's not even a Haynes manual for those cars (to my knowledge) so it'd be pretty much take apart and put back together like you saw.
Question is has anyone ever changed one on an old school rwd car? Is it hard? Anything special to look out for? I know they don't have hydraulic systems but I'm not sure if that stuff needs to be changed/adjusted, and if it does I don't know how to do it.
All in all I'm probably not going to tackle this unless some guys in here tell me that it's pretty simple.
, Maybe not that easy but its easy. I changed the clutch in my 55 ford crown vic Y8 in two hours by myself. The hardest part we re adjusting the column shift rods. That took 20 minutes. A cave man would just sit there and club it until it came off.
My father and brother in-law replaced this yesterday while I was at work, they said it sucked real bad, after Bible study last night I go over there and all they got done was swapped to the new duel fuel rail carb, put the starter back on, do the pilot bushing, flywheel, clutch disc, pressure plate, and bell housing....in like 8 hours! And they're not slow, it's just that this job is being horrible.
I don't post unless I'm pretty damn sure I'm on the right track - I suppose I was vindicated in this particular instance
