Equal length exhaust manifold (EGT probe location options)
ThanatosG
Aug 10, 2004
Dayton, Ohio
Well i purchased one of those crazy expensive DNP manifolds. im about to figure out where the egt sensor is going to go. I really don't want to drill/tap the manifold its too pretty :cry: anyone else out there using a different location without losing too much accuracy? i was thinking maybe my o2 housing. Im also curious if anyone knows a rough estimate of the temp difference from the runner to the o2.. or something similar hell the reason i bought the manifold was because i didnt want to grind on my wastegate/turbine housing. originally i had a ported evo III... but clearance issues with the 40mm tial flange.
anyways if anyone could share some suggestions/opinions
Thanks
i think an EGT probe will add to the sexyness of the manifold. Simply put, why chance with inaccurate readings?
