Engine swap harness question?
Here you go, this link has everything you need to know
http://www.dsmtuners.com/forums/articles-miscellaneous/245684-how-convert-4g64-spyder-6-bolt-4g63.html :thumb:
I just did my 6bolt swap on my gs spyder.I ended up using a 95 ecu and harness every thing hooked up just fine. but the gs spyder wire harness will also work you just needs a knock sensor wire and the injector suppersser (not sure what it's called) and an ecu. I changed mine because of a bad harness from a small fire :ohdamn:
