engine repair price
MelloEclipse
230
Feb 15, 2006
benson, North Carolina
So just got the car back from the shop..had ALOT done to the motor, what do you guys think of the price?
Description amount
Spark plug tube gasket 2.50
cam seal (2 of them) 14.90
intake manifold gasket 3.75
timing belt idler pulley 59.85
timing belt 83.10
water pump 98.35
head lamp switch assembly 87.50
water pump seal 4.75
exhaust manifold gasket 7.20
head bolt (LONG) (6 of em) 24.00
head bolt (SHORT) (4 of em) 14.40
valve cover gasket 14.50
Cylinder head gasket 45.95
oil filter 4.59
oil 7.96
anti-freeze coolant 9.95
machine shop services-resurface head 42.00
machine shop services-clean and flow test head 33.69
machine shop services-pressure test head 39.20
replace headlamp switch 50.00
remove and reinstall cylinder head 460.00
shop materials ( LOL ) 2.00
TAX 33.97
TOTAL PRICE: $1, 144.11
so what do you think, good price? and what now, that the motor is in tip-top shape...LOL
CAI, or exhaust first?
its not bad but i would of had arp head studs put in at least while i was there and i hope you did the timing belt tensior because that usualy goes alittle after the timing belt and stuff does i had a 96 eclipse with the crapy neon motor in it and i had a head gasket leak and stuff i found out after i changed my timing belt water pump alantor belt and a few other things i didnt change the tensior because i honnestly didn't know and guess what happened about 10-15k miles later? you guessed it i got a loud ticking noise the tensior went and had to have the timing belt and all that crap riped apart again....but your price isnt that bad for what you had done
