Engine Option?
SuperMario
Jan 31, 2005
Burlington, Washington
Well the mighty 4g63 took a dump on me and now im tryin to find out the best solution to gettin her back on the road. Well i was wondering what my best option would be, rebuild, evo III swap?, or buy another engine?
Depending on what went wrong with yours, I'd go for a straight up rebuild. No real need to go through the hassle of finding an EVO motor and swapping it in when you could do whatever you want to your 6-bolt when its out.
Considering your profile and the car you have I would def. recommend the 6 bolt rebuild. It would be way too much of a pain to put an evo motor in your 1st gen. If you had a 2nd gen then it would be a consideration. The evo is not worth all the work you would go through to do the swap. the 6 bolt is a very good motor so use it. :dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
