trunks
- 132
- 1
- Apr 4, 2007
Annandale,
Minnesota
Okay dumbass question but - I've read a lot of threads and cannot find the answer. Should the rod boot be right down the middle when in neurtral or when in gear?
I've got what seems to be the dreaded new clutch, no go into gear, shifts fine when not running, grinds in reverse, adjusted clutch rod, bleed sytem till half a bottle of brake fluid gone, want to hang myself situation. If read all the threads so I guess new master cylinder first I guess. Them pull the thing back apart. Just want to check on the pushrod situation - and no I didn't replace the ball like I should have because I'm a dumbass as stated before.
Thanks!
Thanks!
