engine gasket kit
95burgundyesi
816
9
Feb 8, 2006
Rockford, Illinois
Well im looking at the full engine kits on venders pages and i had a buddy say check ebay. Usually a gasket is a gasket. The dail drivers I will use a parts store gasket and I dont sweat it.
Just wondering if anyone else has used a certain companya nd found them cheap and good. Or is there any kit I should stay away from? eems like every vender has thier own kit they sell.
the best choice is the OEM mitsubishi full gasket set , you can find them on SBR and STM .
dont search for cheap gaskets , i cant risk on it and i would to use OEM parts .
Dont be cheap with the gaskets, cause you know whats going to end up happening. JNZTuning.com is where you need to go to get some quality gaskets for cheap.
x2 Cheap work almost always ends up being the most expensive in the end :notgood: Especially maintenance-wise.
I'd say buy OEM. They are only like $175 for a complete kit from JNZ. Most other will only be saving you a few $ at most...
    • Sdcryan1
