Engine Computer Swap
adamsdarin
30
Dec 21, 2004
La Porte City, Iowa
is there a difference between a 1995 Engine Computer and a 1997 Engine computer or is it a straight swap?
They are plug & play as far as hook-up, however, the 95 ecu. has an inverted firing order (you will need to swap the 2 wires on each coil to the opposite coil). The cas.signal is also inverted, however, it will run that way. You could also swap #`s 1 & 2, &#`s 3 & 4 injector plugs to accomodate the inverted cas. signal to keep the inj. timing correct.
Here`s more info on cas. inversion :
http://www.dsmlink.com/faq.html#latemodel
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
