Engine buzz/vibration over 4.5k rpms- balance shaft?
tbnsw
May 24, 2004
Detroit, Michigan
Hi everyone
I just bought my 3rd DSM, a clean 90 Laser Turbo with 56k miles. It had a new timing belt, balance belt and tensioner 5k miles ago. My problem is that when the engine hits around 4500 rpms, the engine sounds really buzzy and there is a vibration. It runs fine, boosts good, doesn't miss or anything. I'm wondering if whoever did the balance belt didn't line up the shafts correctly? If this is the case, would I harm anything by leaving it the way it is? Could it be a harmonic balancer? Any other ideas or things to check?
Thanks for the help
Shawn
Either one of those is a good guess - although if Shafts were out of time you'd typically see Vibes at idle. All the original Harmonic Balancers seem to be bad on these things.
Thanks for the reply, Buck. I will look for a vibration at idle, though I didn't notice one before. I guess I will also try replacing the harmonic balancer. If that doesn't clear it up, can I just leave it, or will I damage something?
Yeah it sure is! It's near mint. I'm still amazed I found it! I'll attach a pic to my sig when I get a chance.
So how would I go about re-tuning the balance shafts- is it involved enough where I should take it in? I've replaced a 14b turbo before but never done anything timing belt related so I'm a little unsure of myself.
Thanks again for the replys everyone.
Shawn
I found the VFAQ walkthrough after I posterd- sorry. But I'm wondering, is it possible to remove the balance shafts without removing the timing belt? In the VFAQ thhey only talk about doing it with the t-belt off. Since the belt is new, I would prefer not to touch it.
Thanks
tbnsw said:
I found the VFAQ walkthrough after I posterd- sorry. But I'm wondering, is it possible to remove the balance shafts without removing the timing belt? In the VFAQ thhey only talk about doing it with the t-belt off. Since the belt is new, I would prefer not to touch it. Thanks
No.
