1G engine bay clean up
4g63t gsx
Aug 16, 2012
jerome, Idaho
i am doing a engine bay shave and wire/brake line tuck and i wanted to know what is the best thing to use to clean it all up, all the grease. and maybe some thing that would strip the old paint.
The clean all the grease go pick up a gallon of purple power from the part store or walmart. That is the best thing on the market and it works amazing. As for stripping the paint, you can use a chemical stripper, or sand it. The chemical stripper is very toxic and i would try to avoid it. I would just scuff the original paint, spray sealer than spray paint on it.
Purple power or any degreaser and a pressure washer. Or just a hose and some elbow grease ;)
If you're trying to get rid of the paint, as well as clean the bay up. I suggest you use a big old angle grinder with a heavy duty wire wheel. Use some simple green and a power washer and you're good to go. :thumb:
Another really thing to use is aircraft paint striper If your going to repaint just spray it on. (where gloves) watch it bubble and spray it or peel your paint off.
As everyone else has said, Purple Power works good. Make sure to get the spray bottle AND the gallon jug. You'll thank me later. You might also want to grab some of the CHEAP WALMART brand engine degreaser. I had some laying around so I used that on top of the PP on my Colt. Here are the pictures before and after. OH: do not forget to get some brushes to scrub. You can find some in WALMART either in the floor cleaning section, or in plumbing.
After cleaning and scrubbing.
Again, this just shows the difference.
As for cleaning and/or removing the paint/rust; I used a sand blaster and about two and 3/4 bag of media (or sand). It worked out pretty well.
Hope this helps.
"Super clean" hands down best cleaner EVER!! It makes purple power, simple green and gunk look like rookies. Best bet is to get a gallon. You'll be wanting to clean everything once you see how it bad@ss it is, i know i did LOL
Im doing the same with my car. Iv just been using a stripping wheel.. ill post a pic.. it rips right through both colors.. it use to be red and got painted black
/Users/masterwolf420/Pictures/pro street DD low cost build/DSCN0112.JPG
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
