ECU with brain cramps?
DSM1G90
5,096
75
Apr 6, 2008
Nampa, Idaho
The car's CEL light came on and doing the VOM pulse test, it pointed to the Coolant Temp Sensor, which indeed was bad - no resistance coming from it.
Changed that out, undo the negative cable on the battery to clear code for a minute, reconnected cable and did the VOM test to make sure the code was cleared out. Yep, - series of short and fast sweeps on the VOM scale that the ECU was in normal operation mode.
Took the car for a spin. CEL light came on again. Did the VOM pulse test again..."still the same short and sweeps displaying normal operation" were the results.
Repeated the battery thing and another VOM check: short and fast sweeps of a normal ECU.
Took it for another spin and same again: CEL light came on. Did the above tests and same results: Normal operation..
Dang...what gives now? :confused:
thx-DSM
