ecu question :/// wisemen help pls
classic69
48
Mar 30, 2005
Binghamton, New York
okay so i have a 92 eagle talon turbo awd and i put this ecu in MD 128624 which is supposedly an NT ecu but i have a nagging suspicion that the guy that had the car before put the wrong cover on the ecu, so my question is would the car run normal and boost great with an NT ecu because mine runs great and is very fast but i want to make sure i have the right ecu because the idle is crappy it lopes from 500 to 1000 . i opened up the ecu and wrote down some numbers from teh chips and stuff if any of the wisemen could possibly help
MH6111 E232 2916B E527 4472A number on the board is : JE331A979A
i couldnt take a picture because 2 of the screws are stripped i can only get half the cover off slightly by bending it , please all help is appreciated.
5/88-6/90 - MD128624
E2T34472
this is the number on the cover of the ecu since it is supposedly a 90 ecu wouldnt the wiring be different since im using it in a 92 car.. i tried a 92 ecu in a 90 car before and it wouldnt run the car at all it would just stumble and die but this one works good
