Ecu "learning" idle?
Kingarex
95
Jul 3, 2012
Cheney, Washington
So I recently did a complete teardown and build, but I'm still having a problem with random high idle. This happened before the build on the English tune so I am leaning against vacuum Leaks etc as I've completely redone the vacuum system with steel braided surround vacuum hose and deleted the agr stuff.
Here's the problem:
Randomly (meaning irrelevant to water temp, air temp, drive time, gear, speed, vacuum/boost) My car will randomly idle at around 2k.... I haven't found any sure patterns... Other than this thought... It's as if after driving on the freeway at 3k for a while, my ecu decides "this must be where he wants his idle" then changes it to that. And after traffic jams cruising in first gear for a half hour at 4th it decides "we've been at 750rpm, that must be where it should idle"
Am I out of my gourd or is this a possibility? Ecmlink v3 BTW.
The throttle cable doesn't stick, cruise control doedoesn't work but that's it (didn't work last year either.)
I honestly don't know. I'll check. But why would it be good some days and not others. Or good some miles and high the next
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
