2G ECU injectors trigger swap
kreepscort
118
Jul 19, 2003
Kearny, New Jersey
well im just about finishing my 6 bolt swap and now im trying to swap the ecu injector wires... is there a way to swap the pins themselves or should i just snip the wires and splice them? any help is appreciated, thanks :thumb:
Just swap the pins themselves. Its the bottom connector. on each side theres going to be little flap that you have to unclip so the wire can come out. Once its uncliped get a small screwdriver and from the fron of the harness theres a little clip the you have to pry up on and pull the wire out at the same time. After your done the wire will just click back in.
thanks, now just to make sure... is the front side, the side that the wires come out of, or the side that the pins show? thanks :thumb:
i got as far as opening the flap, but now im stuck and not sure what to do i have small screwdriver that fits inside the pin holes but i dont know what to look for? can somebody help me out here? im hoping to finish this swap today.
