ECU injector driver questions
boost97gst
3,034
137
Apr 2, 2012
st jacob, Illinois
Ive searched and not found anything on replacing the actual transistors in the ecu. I havent popped mine open yet. Im wondering if anyone has experience with it?
Backstory: After getting socket conversion and link(only 300 miles after i bought the car iirc) i get random cyl 3 misfire and it goes lean. SPARK IS GOOD. Please, ive been down that road.
Anyway, if i flick the keyswitch off then on it goes away. Well, first things first test injectors, resistor box and wiring to the ecu. ALL good. This has done this on a brand new set of pte 1000s and now a set of freshly benched/cleaned bosch 1600s.
It got worse the other day when i tried to start it up and it was only running on 3. No turn off then on trick this time. It was steadily running on 3. And even pulling the #2 injector as well didnt seem to effect it. Weird.
Pulled plugs to verify and sure enough one is leaner than the rest. I wiggle some wires around and test a few more things.
Weird thing is it started running right, or what i THINK is right at this point, and i drove it for a bit. All looked decent and pulled well. Im thinking since ive exhausted every other possiblity its the driver for the injector, which if im not mistaken will be a FET or transistor located in the ecu. One thing after another with this car. It just wont stop.
Also of note: When it was "running right" i could pull injector 2 and barely notice any change at all. Pulling 1,3,4 made it really stumble. So im a bit confused if you cant tell through the rambling. Sorry for the long post and thanks fellas, and ladies.
Alright so the reason you couldn't tell any difference when pulling the injector was cause is because something using reading it so it could be your ecu but you would be better off just replacing the ecu if you have any questions just let me know
