eclipse rs 99 Rear knuckle assembly
KDFECLIPSE
Oct 2, 2013
america, South America
hello I have a broken Rear knuckle assembly passenger side the thing is that i want to change it, but i don't know if there is a difference between the abs and no abs knuckle
my car came with brake disc on the 4 wheels i don't know why because since it is RS version but the abs is not working ( i know it because i don't have the abs module )
the question is even i have rear brake disc can i use the Rear knuckle assembly for drum brake ?
thanksss and happy new 2014
There is a difference between the abs and non abs knuckles. The abs will have a hole for the abs sensor to screw into, while the non-abs knuckle won't.
If you don't have abs you can use either knuckle. If you have abs, you can only use the abs one.
There is no difference between drum vs disc brake knuckles.
The 2000-2005 eclipse knuckles (3g) will also work in the rear, but the same abs rule above still applies.
Note: This info is only for 2g fwd cars
