Eclipse BOV problem
speed3380
Aug 12, 2004
corona, New York
Hi i just finish intalling a Star performance turbo kit stage 2 on my 97 gs and it came without instructions...My Problem is were does the BOV goes connected to and I am also installing a oil catch can that has two nipple for hoses can some one tell me how to do this please...the last thing is, i have the obx adjustable cams what is the best suggestion on degrees to get best results..is it retarding or advancing and to what degree..
i might be able to help but then again maybe bot i have the hrc stage 1 and there is piping on your stage 2 that goes from the turbo to the intercooler then piping that goes from the intercooler to the intake manifold see if there is a hole that is on either of the 2 pipes about the size of a silver dollar that is how mine was if you have 1 it is probly on the pipe that goes from the intercooler to the intake manifold but check both of them
Do you have a bov or bypass. I have a bov greddy type s, i can tell you how to hook up that. I have the star kit stage 2. Let me know what else you need if your stuck.
the BOV goes on the pipe after the intercooler and before the intake. They might have supplied a pipe that holds the BOV, if not they should have giving you a little round metal peice you would have to get a muffler shop or yourself to sodder it onto the pipe, than pop the BOV on it and tighten the screws. than you hook you boost controller line to it from the T split.
