ecipse engine bay help
DSM_GSX01
984
14
Jul 27, 2011
La Junta, Colorado
need some help on should i paint my engine bay? also i don't know if i should paint it the original color green or different? any advice? i have the engine pulled too?
Painting the engine bay is your own decision. As for what color, same thing your decision. And why is you have your engine pulled a question? LOL I have a silver exterior and i rattled canned it black in the engine bay looks pretty good
Flat or semi-gloss black looks good and is easy to touch up. Since black matches anything it also leaves you with limitless color options for paint and engine bay color schemes. I would have never been able to go with my blue/purple color scheme if the bay was still red. I'd suggest using "Rust Tough" brand paint from Oreilly's. Make sure to scrub down the engine bay with something like Purple Power prior to prepping for paint.
the color is 95 green. like the forest green. i want to paint it the original color but its expensive. and i have to rebuild the engine.
do you have pics of your engine bay? if so can you post some?
i also am needing help with my build and i put a forum up if any one can help me out. thanks
Using flat or semi-gloss lets any leaks stand out really well since they appear shiny. I'm also not one to wrap the engine/trans in bubble wrap, or be gentle with tools when wrenching, just to avoid damaging a $200 engine bay paint job. Here's a couple pics of my just to give you an idea. Top pic was the first build where I left the bay red and tried to go with it (which didn't really work out). The bottom is how she sits now with semi-gloss black and a mild purple/blue scheme. It's of course not nearly finished or perfect enough, but to me it's a night and day difference.
As you can see, the black really helps to drown out all the background "noise". I plan to eventually install some performance parts that are more aesthetically pleasing as well. Metal intake snorkel, colored rad hoses, etc. I also plan to have all bolt-on silver parts powder coated the same metallic purple as the valve cover. The goal is to have nothing but black, blue, and dark metallic purple.
nice i like it did u take the fenders off to paint it black? also does it peal? and what all did you take off before paint?
I just taped off the fender about midway up the flat edge facing the engine bay. The bolts and everything looked pretty nasty so I wanted to cover them. However, removing those bolts would allow you to pull the fender back a bit, tape it off, and paint underneath it. Just be aware that the fender and engine bay are sealed together with an adhesive.
I admit I was crunched for time and pretty lazy when it came to prepping the engine bay for paint. The engine/trans were out and AC, emissions, crusise control were already deleted. The only parts I pulled out were what I could do in one day. I didn't remove parts such as master cylinder, ABS module, or even the black felt crap on the firewall. I cleaned the bay with a 70/30 mix of Purple Power/Water along with a stiff plastic scrub brush. A final wipe down with grease/wax remover, a coat of primer, and then 3 wet coats of black. I used my digital camera to find any areas I missed and let it dry overnight before installing the engine/trans the next day.
Making sure the bay is clean is the key to the life of the paint. Even with pretty lacking preparation I have never had the paint peel. And I scratch the paint down to bare metal quite often. Low gloss finishes don't need an even surface texture in order to blend, so any damage done can be fixed with some sanding and a quick spray.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
