Ebay Gasket Set?
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
http://cgi.ebay.com/ebaymotors/JDM-...ryZ33667QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I searched a bit and couldn't find anyone's information on this kit -- I bought a $500 car that needs the head rebuilt... I wanted to get all the gaskets as a set, but also wanted a good head gasket -- so felpro is out of the question. I do not want to buy a whole gasket set, throw away the head gasket and buy a good one if I don't have to. Anyone have any ideas? Thanks in advance.
I should also note that this car will be seeing a EVOIII 16g or PTE 50Trim and around 22psi of boost.
Think an OEM Gasket would do fine?
This is my first head job on a DSM -- Anything I may be forgetting?
for sure go for that kit, it is basically the same quality as oem stuff, but alot cheaper, plus you get a mls head gasket, that is comparable to the mitsu 4 layer. I have ran the head gaskets before, and they work great, the rest of the gaskets are good too, there are also ajusa full gasket sets on ebay for 89 bucks, that includes everything from turbo mounting gasket to valve seals, injector o-rings, every gasket that you will need. that iw the set that i use in most of my motors, the ajusa heas gasket is good for upwards of 375-400 horses, that is of corse on a properly tuned motor. But the nippon stuff is very good too.
I've ran a few ebay gasket sets with good results.. I never use the headgasket though, but i hear they are good too.. I also copper spray my gaskets which make them even better.
