E-manage????
96eclipsex
93
Sep 29, 2005
Rutledge, Tennessee
If I get the E-MANAGE BLUE For My 420a Turbo I wont need a FMU or Afpr will I????
Does anyone know what kind of fuel system I will need with the E-manage blue???
The emanage doesn't adjust fuel pressure so if you are putting a turbo on your nt then you need a afpr. All the emangae will do for you is adjust the timing and air fuel ratio.
There are a few ways you can configure your fuel system. If you stick with stock injectors and just use the E-Manage for electronic fuel trim modification (virtually no different than an S-AFC), then you'll likely still need an FMU, as the E-Manage unit can't force the ECU to adjust that radically for boost. Otherwise, if you use larger injectors and/or utilize the E-Manage's auxillary injector controller, an AFPR is what you'll want.
