E-Manage Installation
dennis-1009
65
Sep 7, 2009
Loch Sheldrake, New York
I am trying to install my Greddy Ultimate EManage and am having issues with the wiring. I am not sure where to connect all of the wires. I have the ecu harness out but I have to connect the rest of the wires. I have attached a picture and was wondering if anyone knew what it was a pic of. Thank You.
It sounds like you are trying to perform a hard wire installation. Do you have an electronic or hard copy of the manual? BASIC operation requires simple wiring much like that of an A'PEXi S-AFC, and it goes on from there with ignition timing control, etc. If you feel that you are biting more than you can chew, you should probably get a patch harness or completed boomslang.
Any reason that you are installing this onto your '98 as opposed to flashing the ECU?
I did have an apexi s AFC and someone stole it and ripped it out of the car. They are not in the ecu harness and I needed to know where they are and the color coded so I can connect them. The wires I could not find are the injection input and outputs and ignition input and output. Thanks.
