dump tube/boost question
moonstation2000
88
Jun 23, 2003
I have a big 16g with an external dump. Problem is, i can hear the dump opening at 12 psi even though i max out at around 19-20 psi by redline. Shouldn't my dump tube stay shut until i hit max boost?
Yah mine does the same thing, i also have a big16g set at about 20 lbs and at low boost i can hear it opening. I still get to 20 lbs but i hear it dump early. Why?
Same here, big16g with dump tube set at 20psi. I can hear exhaust coming from the wastegate at part throttle or 10psi.
In a perfect world, yes the wastegate would stay shut until you hit your desired psi (say 20) and then open, and you wouldn't get any over shoot or anything. But since it's not a perfect world, I guess the wastegate starts creaping open anticipating your set 20psi; so you hear it, but it's not fully open yet. This isn't ideal, since that exhaust gas escaping could rather be used to spool up faster or reach your desired psi setting quicker.
Some say that an electronic boost controller would fix this problem, but I don't buy it.
You could try an FP upgraded actuator. It comes with a stiff 17lb spring.
Besides with an internal gate it will always open a little early
The fact that it opens early is the way it works...If it didn't Open untill your desired boost setting it would be to late and spike... By opening early it controls the boost just right and makes it level out where you have it set.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
