dual wastegates??
dual wastgates would be recomended if the backbreasure cannot be relieved enough with one wastgate to hold the desired boost .:)
My tial 60mm wastegate is bigger than 2x38mm wastegates. If you run high boost then you don't need much of a wastegate.
i really never understood them just thought they were on high compression engines
Lol isn't 38+38 76mm...
So technically wouldn't two gates... You get the idea.
....thats not how you calculate how much surface area the valve has, or area of a circle that is.
38mm or 60mm would be the diameter, AREA (A) for a circle is Pi x R2 (2 represents squared)
60mm - A = 11,304mm squared
38mm - A = 1,134mm squared
2x 38mm wastgates = 2268 mm
1x 60mm wsategate = 11304 mm
They are on all turbos, some internal, some external. The little silver or gold thing that sits by the compressor is the same thing as the silver or colored tial units. Every turbo needs a waste gate or it will never stop making pressure and will most likely over spin and kill it.
2x 38mm wastgates = 2268 mm sqaure
Okay math wiz, you win :)
no i was talking about running dual wastegates
you need to keep the 2 sides separated up to the face of the wastegate valve if you are using a single wastegate on a twin scroll setup
Is there any negative sides to running a twin scroll manifold and using one wastegate (like the manifold you linked)?
See above, it adds a whole layer of complexity to fabbing the manifold.. and if you are not intending on running a lot of boost, you will need a very large gate.
The more boost you run, the less valve area you need on the wastegate.
Just something to keep in mind. For example, I'm only using two 38mm gatess in stead of 44s because I will not need to bypass a lot of exhaust around the turbine.
