dsmlink log, knock on stock boost??
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
I just got a 97 GSX and i did 2 logs the first one was 2 degrees and the second was 5 which is weird casue both were 3rd gear pulls and this is on 15psi, my mods are:
AGP 50 trim
44wg
3"truboback
greddy fmic
denso 550
255 pump
fuel reg
fuel rail
264 cams
cam gears
pullies
bltz bov
You need to go to the dsmlink forums.
I think you need to do a leak test. Stuff doesnt seem right, your timing is low and your not over running your injectors. I say do a leak test and then go from there.
15psi from a 50 Trim is not Stock Boost :thumb:
You need to get your fuel trims in order and also you need to set your airflow sliders so boost est. matches your boost gauge around 5500rpms.
