DSMChips stage 3 95 ecu (Keydiver), now low timing
What was the last thing you did to it that made it not work? Was it the ECU? If it wont start try checking out the CAS and see if its plugged still plugged in.
the last major thing was install the new chipped ECU. i had keydivers do a stage 3 chip with some features for running my new injectrs and whatnot. then it just started running like crap. i talked to jeff about it and he said he went through and double checked the code and everyhting was fine. but for some reason it wont run for nothing.
thanks,
chris
o got my car to rev up now, but the problem is now backwards. before it wouldnt rev at low RPM's now it revs fine at low and wont rev past 4k without backfireing horribly. the problem with the low rpms was my SAFC wores. they werent securely sodered on. so i fixed them and the car revs fine.
i now need to find out why the stupid car backfires so bad at high rpms. and why would i have to change the spark plug fireing order. i still have the factory 7 bolt motor. its just been completely rebuilt. the fireing order should still be the same.
and i havetn checked to see what my timing is lately, but last i checked i was stuck at 0~1 ish. and i know it should be at +5 or so.
anyway what would make my car backfire so badly at 4K (so bad it will not rev up any higher)?
i need to know, my car has been down way too long and i have dumped way too much money into it to just let it sit there and look cool.
thanks,
chris
i prefer you make your own thread instead of stealing mine. you'll get alot more answers as alot of people have already looked at this thread and it is old news to them so they dont bother coming in anymore.
