For Sale DSM Tuners/Shootout Special!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
This offer is only being posted on the DSM Classifieds group and DSMTuners forums - These 2 sites in particular support me and my shop more than any others so I'm returning the favor!
PLEASE click LIKE that keeps the post visible!
DONT SEE IT? ASK! - I have the second largest DSM Parts inventory in the country!
RIX Racing - We are located in Morgantown WV - Willing to ship - and will deliver anything for Free to the shootout!
I also offer remote tuning and local dyno tuning here on my AWD Mustang Chassis Dyno in Morgantown WV.
Purchase over $500 and get 50% off a tune... Purchase over $1000 and comes with a free standard tuning session!
This offer will remain good until the Shootout and applies to either remote OR dyno tuning!!
DSM Stuff
Rebuilt Fuellab Prodigy fuel pump $425
88K mile super rare lime green color Stocky stock VERY rust free(Nevada car) 95 Talon TSI FWD Automatic - $4500
Purple Sparktech "Drag" COP DSM Ignition - Pro-12 M&W CDI - $900
Brand new BSFab 3" vband downpipe with New clamps and flange - $450
Comp Turbos Billet 6765 T3 Turbocharger - $750
Garrett GT35R dual ball bearing t3 turbocharger - $850
FIC "EasyTune" Box - $325
Built 6 bolt shortblock - $2400
3000 miles very healthy
complete deck down
Eagle Crank
Scat Rods
Manley Pistons
MHI Pump
complete deck down inspected
Built 6 bolt Shortblock - $1500
OEM Crank
Ross 8.5:1 Pistons
Eagle rods
MHI Pump
BSE Delete
complete deck down
healthy pull - inspected
refreshed Built 6 bolt shortblock $1750
Eagle rods
wiseco pistons
MHI Pump
timing belt broke so there are some marks in the pistons from valve contact that we cleaned up and reinstalled
new acl bearings
new rings and fresh hone
cleaned and inspected
Semi built 2g head - Crower springs and retainers SS Valves fresh deck and valve job - $425
Semi-built 1g head - recently decked with valve job , stock valves, Supertech dual springs and retainers - $500
DSM GSC S3 Cams (Has also been drilled to accomodate a 2gb CAS if necessary) - $425
DSM Kelford 294/292 Cams - $475
Freshly Built 2g Automatic transmission - Kiggly Frictions, Translab shift kit, Welded Diff, new band seals gaskets and other consumables, fully inspected line pressures adjusted to Kiggly spec no core required - $2500 - - Add Billet Transfer gears for $1500
Freshly Built 1g Automatic transmission - Kiggly Frictions, Translab shift kit, Welded Diff, new band seals gaskets and other consumables, fully inspected line pressures adjusted to Kiggly spec no core required - $2500 - - Add Billet Transfer gears for $1500
Healthy used 7 bolt long block - 850
Healthy used 6 bolt long block - 850
Good 2g AWD 5 speed Transmission - $700
Good 2g FWD 5 speed Transmission - $350
Good 2g LSD Manual Rear diff - $225
Good 91-96 23 spline T-case - $150
90-96 manual half shaft with carrier bearing - $75
Good 92k mile 1g 22 spline manual trans - $350
Good 92k mile 1g 22 spline tcase - $150
Turbonetic style cast t3 exhaust manifold - $100
Cleaned and serviced ID 725 HI-Z injectors - $350
Cleaned and Serviced FIC 775 HI-z Injectors - $325
Cleaned and Serviced PTE 1200 Low-Z Injectors - $295
Cleaned and Serviced Bosch 1450 HI-Z Injectors - $425
Uncracked valve cover with -10 an fittings tapped on the top(sleeves welded in) - No baffles - $100
Skunk 2 Super lightweight Adjustable cam gears (gears are nicked up in the holes but work fine)(Silver) - $130
2g non cruise cable - $35
2g non abs lines and prop valve - $85
1g non abs lines adn propvalve - $85
Accufab 75mm Throttle body - $150
SBR/HAFE Exhaust manifold flanged for 38mm 2 bolt wastegate - $225
A1 H11 Head studs for 7 bolt - $185
ARP Standard 6 bolt head studs - $50
3g no-tick lifters - $65
2g Tokiko Illumina Adjustable Struts with Tokiko Red springs - $400
2g Tokiko Blues with tokiko red springs - $250
Good used Gates or Greddy Kevlar Timing belt - $45
Oil filter relocation kit - 100% filtration - $125
Aeromotive AFPR - $125
17" Rotas - No curb rash - $400
Freshly rebuilt by Justin whitesell Genuine EVO 3 Big 16g - $500
Fluidyne 2g Radiator - $200
Vibrant spark plug cover - $45
Shaved Valve cover painted black with -10 an fittings welded on Lines and catch can - $250
FP Intake with couplers - $100
Mishimoto fan shroud with fans - $75
Home made COP setup works with 1g or 2g (May need to switch 2 pins depending on yoru config) - $150
Mitsubishi(with the diamond star) badged VC no cracks - $125
BBK 62mm Throttle Body - $150
AEM Wideband - $125
LC1 Wideband - $130
EVO Stuff
I have 2 EVO Parts chassis's available with good panels and parts if you need bumpers or fenders or doors etc one is very low mileage at 49K but no title.. need something ASK!
SORRY I dont have ANY good headlights trunk carpets or tcases :(
Complete Forward Facing Turbo setup - $3150
Sheepy FF Manifold
VBand .82 PTE 6766 DBB
Vband Turbosmart wastegate.
Feed Line
Return Line
Hood exit exhaust
hood exit wastegate tube
Half sized Mishimoto Radiator
Lower Intercooler pipe
Built EVO 9 shortblock - ~3000 miles on the build very healthy and still installed will pull on sale!- $4850
MHI Pump
Balance Shaft Delete
Wiseco HD 10.5:1 pistons
Manley H Tuff Rods
ARP Main studs
TRI Metal bearings
Bushwacker stage 2 5 speed with stock ratios - $2250 each
Nice EVO 8 Steering wheel with airbag (only 49K miles on it) - $285
Comp Billet 6765 T3 Turbocharger - $750
Old School Garrett GT35R T3 Turbocharger (dual ball bearing) - $850
EVO 9 GSC S2 Cams - $425
EVO 9 GSC S3 Cams - $425
EVO 8 HKS 264 Cams - $325
EVO 8 HKS 264/272 Cams - $325
ARP L19 Head studs - Brand new - $225
A1 H11 Head studs - Used once - $200
BNIB Walbro 450 pump - $85
EVO 8 Wheels - $500
Exedy Twin Disc (needs discs) - $200
QM Twin Disc w/ Hydraulic TOB - $950
Working ACD Pump - $350
Cusco Sway Bar - $200
Non ABS Master cyl from an RS - $125
2 bolt F38 Tial wastegate - $125
STM Front Drag Brakes(EVO8/9)(Fresh rotors) - $800
Torque Solutions motor mounts - $325
AMS VSR Intake Manifold - $475
EVO Brembo Brakes $525
Boomba Throttle body - $350
Magnus SMIM - $400
Wilson 75mm Throttle Body (matches the above Magnus) - $150
evo 8/9 SS Upper intercooler pipe 2.5" mandrel bends Tial flanged - $140
Buschur double pumper for evo 8/9 w/ 2 255s - $400
Genuine Stanley EVO 7 Tail lights - $600
Blox front rollstop - $75
AEM Wideband - $125
EVO Fenders $200 a piece
EVO Doors - $200 a piece
OEM EVO 8 Tail lights - $150
Tarmac black EVO 8 front bumper in OK Shape- $200
RR Hood has baseball sized dent in nose very repairable - $250
Crappy carbon fiber hood - $150
EVO 8 Engine harness - 225
VERY GOOD Blue cloth seats from a 49K mile chassis - $500
49K mile EVO 8 Rear diff - $650
49K EVO 8/9 Rear axles - $350
Lots of dashboards with airbags
lots of consoles
several clusters
tons of Misc.
I am positively missing things this is just a top of my head list!
