For Sale DSM Parts galore
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
All parts located in Morgantown WV
Prices do not include Shipping
Call or txt 304-813-2405
Refreshed DSM 6 bolt shortblock- 0 miles since being refreshed
Complete from the Deck down
Crower I beam rods
JE HD 8.5 pistons
.020 over
ACL Race bearings
ARP main studs
Kiggly Girdle
MHI oil pump
SS Orings
Line Hone
all new ACL Race bearings/JE rings/and SS o-rings
This shortblock will handle ~800 Horsepower
$2350
Refreshed DSM 2.4L 7 Bolt Stroker Motor
Manley H beam Rods
Wiseco Pistons
ACL Bearings
ARP Main studs
MHI Oil Pump
SS Orings
Line Hone
$2000
Healthy 6 bolt "Frankenstein" Longblock
Valve cover to oil pan
2g 8.5:1 Pistons/6 bolt big rods
175-180 compression across the board
$950
Old School FP Garrett GT35R Dual Ball bearing – Inspected by Justin Whitesell and given clean bill of health - Includes Tial wastegate and 3” O2 housing - $1050
DSM Chinese 16g - 75
Mhi tdo5h 20g - internal gate with holset actuator - rebuilt with 0 miles - 425
PTE 4431e setup for external gate off manifold - DSM bolt on - rebuilt 0 miles - 475
DSM PTE 6031e with DNP Manifold custom 3” o2 housing internally wastegates 675
good used 14b turbo - $125
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
Cleaned and flowtested EVO 560s - $100
cleaned and tested RC 1000cc injectors - $250
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
Cleaned and flowtested FIC 750 Hi-z Injectors - $350
Cleaned and Flowtested PTE 1000 CC low-z Injectors - $265
2g ECMLink V3 w/ ECU - $585
Nice NRG Racing seats on wedge engineering brackets for 2g – 650
FP Exhaust manifold - $225
DSM/FP Manifold Blanket - $95
Aeromotive AFPR w/ Line and rail fitting - $135
Innovate Wideband w/ Gauge and sensor- $135
EVO 3 Intake manifold - $225
1g Head – BC Springs and retainers – Recently touched up - $375
Recently rebuilt to stock 1g head - $300
Fluidamper Crank Pulley - $225
Tial F38 waste gate with stripped hole where fitting goes in in lower portion - $75
Red Tial 50mm Q BOV with flange- $185
DSM Megan racing 02 housing $75
2g Gauge cluster with black indiglo gauge faces $65
Mitsubishi badged valve cover $100
2g shift cables with solid bushing $100
Unorthodox racing crank pulleys $50ea
2g Skunk 2 coil overs/tokiko blue struts $400
Greddy turbo timer $20
Injen Intake with maf setup $100
Black box 2g ecu – 80
2g Tein Flex Coilover setup - $650
Snow Performance Meth kit – 2 jets, some line, an EVO 8 ic sprayer reservoir, hobbs switch, and pump .. works perfectly - $100
DSM BC 272 Cams - $350
DSM FP2 Cams - $425
AEM Digital Boost Gauge- $100
DSM Coil on Plug setup - $200
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
DSM PTE 60-1 bolt on Turbo - $525
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
BBK 62mm DSM Throttle body - $150
Accufab 75mm Throttle body (Mustang flange) - $150
3g "No Tick" Lifters - $65
Good 90-96 manual half shafts w/ carrier - $75
1g 4 bolt manual rear end w/ axles and cups - $400
2g GST 5 speed Transmission - no grinds - $350
2g GST Auto Transmission - shifts as expected - $400
Braille Small battery tray - $65
Genuine Greddy type "RS" Bov - $100
Genuine Greddy Type-S BOV - $100
BSFab DSM forward facing T4 Twin Scroll Manifold - Brand new - includes dump tubes - 750
BSFab DSM 2.5" side exit - $150
JMFab VBand bottom mount exhaust manifold w/ new Custom VBand 60mm HX40- $1400
97-99 Manual Tcase with only 82000 miles - $175
1990 Manual 22 Spline tcase with only 85000 Miles- $150
1990 Manual 5 speed 22 spline Transmission with 85000 miles - $350
