dsm dont start where to go from here
miller97tsi
221
Jan 5, 2008
jacksonville, Florida
so i am at a lose for my talon. check fuses checked spark and fuel. everything is good. what else should i be looking at any suf=ggestions to help get this car back on the road where it belongs
i will try a compression check and i will also check the coolant temp switch as well anywhere else i can look
like said above check the CAS. i had a no start car and found the CAS wire was melted in half so yours could have a possibility
I had the same problem and i got a cheap used ecu off ebay just to see if it affected my symptoms and it fixed it. though i recomend if you find this is the issue get an actualy refurbished or new one cause used ones seem to end up with the same issues after a short time of reuse i guess takes the capacitors off their last legs but try a cheap ecu of course for your car but it is a cheap way to diagnose alot with one part.
I am currently having the same issue as the OP. I just bought an eprom ecu with dsmlink just to see if it was the ecu (and to get dsmlink obviously) and it seems to be having an issue reading my CAS. So that is next in the list for me as well.
i am going to check the crank and cam sensor. the cas sensor is brand new maybe it just went bad or something got it ferom the zone. is there a way to check and see if you have a bad fuel pump that has been rewired.
I swapped my cas with my buddies and still a no go for me, im not really sure whats going on now. My next idea is pull the fuel rail and see if the injectors are squirting.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
