where to go from here?
2KaotiK
Nov 18, 2003
Oregon City, Oregon
So my GSX is totally stock.. except recently my turbo went out so I upgraded to a T28, polished my intake manifold and o2 housing, and had a burned valve so did a valve grind. The question is, where do I go from here?
I'm trying to go for a 'sleeper' effect.. so any suggestions on what to do next?
thx :thumb:
thx :thumb:
id say you probably want to fix the burned valve and the valve grind before you do anything. :thumb:
for the sleeper effect, get a large sidemount IC, leave your exterior bone stock, you are going to want new shifter bushings, mount your gauges anywhere except the a-pillar... cause that gives it away to everyone, put your AFC in the glove box, turbo timer some place hidden, get a 3inch down pipe that goes to your normal exhaust, and also to a cut out so you can drive around with a quiet beast and then rip people to shreads by opening your cut out.... i dunno what else to say.
what do you mean 'fix it'? the valve grind was done to fix the burned valve.. so I'm confused.. :confused:
i thought you meant a valve had been grinding... like in a bad way.
I second the exhaust post above. Also, I've seen many members here get a FMIC and either paint it black or get it anodized black so it looks similar to a radiator. Then get some injectors to put out more power with an SAFC/dsmlink to tune with. Port out exhaust mani and O2 housing.
Or...
Just get one of those huge aluminum fins on the back. No one takes any car with one of those seriously... :laugh:
Or...
ROFL, yes! and a type r sticker!
HAHAHA I'm a chick
NOW WHAT FOOLS!
LoL don't mind Chaye. He bought my GSX from me a little while ago after an unfortunate incident with too much boost and not enough fuel and my block deciding it needed another oil outlet..
It is ANYTHING but sleeper now. fawk you could see that thing coming from a mile away.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
