dsm buyer questions.
whiteDSM
40
Oct 4, 2009
Prince, BC, Canada
Well as of today i drove a 1990 eclipse gsx with 164kms. It has the 2g talon turbo, headers, intake, big bov, exhaust and cams. I have been researching these cars a whole lot and was wondering what i should look for when buying one. Timing belt was changed last 10xxxkm. Didnt notice anything wrong except for it needs a new starter.
Let me know guys!!
Well do a compression test on it and see what the compression is.Check the turbo for shaftplay.160k miles is a bit high,but the motor should be a 6bolt no crankwalk problem with it.The 2g turbo sucks its a t25 very small I dont know why someone would but one of those on it opposed to a stock 14b.If its a good price and clean I would get it:thumb:
+1 Can ask what hes asking for it? That always helps on its a good idea to buy or not.
Well he was selling it for 2000 o.b.o. i offered him 1300. has no stereo, interior could be in better shape.. he took the offer without negotiating. cause we told him i have to buy over a 1g in parts including new tires. My dad also notice when we stepped on it and gave it some gas it will smoke white (not a whole lot ) but there is some. I will be check the oil for foam or smell to see if it is a head gasket. ( i have yet not picked it up yet ) so need as much help.
Car is also not insured, so only got to test drive it a couple blocks. performance seemed fine though.
The smoke could be coming from the turbo but definately check all those over as well.
+1 on the turbo smoking. T25's are good for blowing white smoke. Do a leakdown test when you get the car and hope it's not a headgasket. Either way, I think that is a good buy as long as you didn't hear any excessive knocking. Welcome to the DSM world, your gonna be on this site more than you are in your car :p
Ok thanks alot, that really helps !
It could be the seals in the turbo, but thats an easy fix...16g! Your best bet is to do all, and I mean ALL routine maintenance before any sort of upgrades (besides the 16g because you do not have to run it hard and you prob need a turbo anyway). These cars have such bad reps for being troublesome because people think they can beat the crap out of a turbo vehicle and have it run forever. Then they dont replace things and say "DSM's are unreliable".
+1 on the compression check
Change plugs/wires
T-stat/Radiator cap
Oil/Filter/Oil cap
Air Filter
These things should get you wel on your way to a healthy running 4g63. Some of the things listed do not always need to be replaced, but all that stuff can be had for under $100 and in my book I'd rather have the peace of mind knowing how and when all of it was replaced.
Pete
