For Sale DSM and EVO Parts!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
3 Free dyno pulls with $500 puchase or 50% off a Remote Tune.
lets make a deal!
304-813-2405
Morgantown WV
(SCROLL DOWN FOR THE EVO LIST!)
MHI EVO 3 Big 16g - $425
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
Cleaned and flowtested PTE 1000cc injectors - $255
Cleaned and flowtested FIC ASNU 1050cc injectors - $400
2g Skunk2 coilovers w/ Tokiko Blue struts - $425
Brand new 2g/evo Oliver Billet "Ultralight" Rods - $725
Chinese 16g in good shape - $75
2g black box ECU - $75
EVO 8 ECU - $225
BBK 62mm DSM Throttle body - $150
Freshly built 2g 7 bolt short block(bottom end)
Eagle/Wiseco/ACL - 0 miles - $1800
Accufab 75mm Throttle body (Mustang flange) - $150
3g Lifters - $65
Genuine Greddy type "RS" Bov - $75
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
Walbro 255 pump (2g) - $40
BNIB Walbro 450 - $100
63mm Non turbo Throttle body - $125
Competition Stage 3 clutch (Very low miles) $275
Competition Stage 3 clutch w/ 8 puck disc and CC Chromoly FLywheel - $400
4 bolt manual rear end w/ axles and cups - $400
red AEM Fuel rail w/ spacers - $100
2g GST 5 speed Transmission - no grinds - $350
2g GST Auto Transmission - shifts as expected - $400
2g ECMLink SD harness - $50
Brand new GM IAT w/ bung and pigtail - $25
Used DNP Style(No name) DSM Flanged tubular exhaust manifold - $50
JPipes - $25
holset H1c parts turbo has some turbine damage, turbo came loose from its housing- $50
Complete 2g AWD Auto swap in good shape(Includes everything to make your manual AWD an auto AWD) - $1250
Good pull stock 6 bolt head - $225
Good pull stock 7 bolt head - $225
good 6 bolt shortblock -$550
Brand new 2g/EVO Oliver Billet Ultralight rods - $750
Billet Unorthodox Racing Aluminum crank pulley - $40
Good used Greddy Racing Kevlar Timing belt (Blue) - $50
Weldon Inline fuel filter -6an $75
Good stock 95-96 2g AWD 5 speed transmission 110K miles - $700
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
good used ACT 2600 clutch - $225
Act Streetlite 7bolt fwd flywheel - $100
Braille - Small battery tie down/tray - $85
Good 2g MAF - $25
Green powdercoated Brembo brake set w/ rotors and pads - $675
2g Lamborghini style bolt on door hinge assemblies - $250
os giken DSM twin disc clutch - worked well but will need a rebuild - $450
Revised 3g Lifters - $65
2g pair LSD rear axles $200
2g LSD Auto Rear end - $225
2g LSD Manual Rear Diff - $225
2g Non LSD Auto Rear end - $200
2g 91-96 Auto Tcase - $150
22 spline manual tcase - $150
23 spline manual tcase - $150
Good manual half shafts w/ carrier - $75
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
2g AWD Fuel Sending unit - $100
2g non abs prop valve w/ hard lines - $80
1g non abs prop valve with hard lines - $80
Recently rebuilt to stock 1g head - $300
Good 2g short block 95-96 Running pull $550
Good Engine harnesses (1g/2g Auto and 5 speed available) - $150
EVO 9 Steering Wheel - $300
EVO 8 Steering wheel - $250
Red fuel lab filter to rail kit -6an - $85
Healthy 2g 7 bolt long block - Valve cover to oil pan - $850
2g prothane motor mounts (Manual) - $75 (includes the mounts and inserts)
FP Intake recirc w/ couplers - $110
Uncracked valve covers - $75
EVO LIST-
EVO 8 Longblock - 2850
GSC S2 Cams
92000 miles
Doesnt smoke or leak... Engine is quiet and smooth
165 PSI Compression across the board
Cleaned and flowtested Very low mileage ID 1000s - $425
Good used Walbro 255 - $40
EVO 8 Fuel sender assembly - $125
GOOD ACD Tcase - $1100
Bushwacker 5 speed transmission - $2200
5 speed conversion parts - $250
Low mileage evo 9 turbo setup - $500
EVO 8 ECU - $225
Built 2.4L Shortblock 5500 miles on the shortblock - $3500
O-Ringed
Howard I Beam rods
Wiseco HD 86.5mm 9.1:1 pistons
Fully balanced rotating assembly
ACL Race Bearings
ARP Main studs
AMS Oil Pan
Fluidamper Pulley
EVO 9 Steering wheel in 8/10 shape w/ airbag - $300
EVO 8 Steering wheel in 7/10 shape w/ airbag - $225
EVO 8 Wiring harness - $175
EVO LSD Rear Diff - $575
Rear axles - $250/pair
Front axles - $100 each
EVO 8 SSL Seats w/ door cards and arm rest (There is a very small tear in passenger front seat) - $875
SSL Door cards - $200
SSL Arm Center console - $100
slightly used Gates racing kevlar belt - $50
EVO 8 Blue recaros - (Driver seat has a small tear - $350
EVO 8 Dash board - $150
EVO 8 dash cluster - $125
Good used alternator - $65
Good used power steering pump - $100
EVO 8 power steering rack - $150
EVO 8 roof (Not ALUMINUM) (non sunroof) - $150
EVO 8 RS Doors - $650 for all 4 in RED
Fortune 500 coilovers (one good front 2 good rears set is NOT complete missing front passenger) - $250
Apexi N1 Coilovers - $800
FORGE BOV - $90
ARP Head studs - $65
ARP L19 head studs - $200
No-Tick Lifters - $65
STM FMIC Kit w/ injen lower pipe and unknown upper pipe - 600
Damaged set of RPF1 - 17x9.5" - All 4 wheels are damaged see photos(2 wheels are cracked - 2 wheels are severaly curbed, 2 tires are sliced) - $250
There is SO MUCH more here not listed - CALL OR TXT if you need something - 304-813-2405T
Located in Morgantown WV - - MUCH more not listed PLEASE CALL OR TXT
304-813-2405
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
