Drop in compression with new headgasket?
Throwback23
222
7
Apr 28, 2012
Boring, Oregon
I recently noticed that my stock talon was heating up quickly, one leakdown test later my headgasket was found at fault. I bought some felpro headbolts and used a new composite headgasket (looked generic imo) that was given to me. Anyways I had done a cold compression test right before I pulled the head and got 155,140,140,160. Well after the headgasket and timing belt but before installing intake manifold, exhaust manifold, ect...I decided to do another cold test for kicks....good thing I did my cold numbers were insane...125,105,105,110 dry and 155,140,140,155 wet....so now my wet numbers are pretty much where my dry numbers where before...odd...so to my question, what am I missing here and what could cause that? I'm open to input, I'm kind of hoping I'm just having a brain fart, I pulled the head again and I'm ordering some arp studs along with a felpro permatorque hg, a combo Ive had no issues with on bastard 20g talon. As for the torque specs maybe I got the wrong one ??I went 57lb/ft, loosen, 15lb/ft, 90degrees, 90degrees on the bolts but when removed the newer headgasket looked as if it had been clamped 1/3 as much as the one I took off on the edges.. Ideas? Hopefully I'm just newbing out LOL...
Honestly I didn't, I know I should have but I assumed it was fine....I even had the feeler gauges just needed to get a straight edge...I'll def be checking warpage this time to be sure of if it needs attention or not. That could very well be the issue but I didn't consider it to begin with
Well after checking warpage it seems to be .007 between 2&3. Off to the machine shop with the head... While I was at it I figured I would check the block for warpage and I didn't find any but I managed to fail yet again. I've been on a streak of making dumb mistakes and it sucks, anyways I bought a new pack of razors to clean the blocks deck... I reached for a blade and got to cleaning, a second later I realized I had two scratches on the deck. I had not grabbed a new blade but an old one with a burr right next to the new ones. How does that happen, face palm. Anyways the scratch doesn't catch my fingernail but if I go over it super slow I'm pretty sure I can feel it. I'm hoping a permatorque can have its way with that scratch so I can forget about it and call it a day but I'm sure I'll hear otherwise LOL. I've never used copper spray but would anyone advise it in this situation? Thanks for the help.
It looks deeper then it is when the flash hits it just right....
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
