Driving with no MBC?
KaLo_o
227
Mar 9, 2009
Quebec, QC, Canada
my car is pretty much ready to go and i cant find my MBC, i sniped off the boost control selenoid a long time ago since i had a MBC. can i run my car without any of these?
you can run a vaccum hose from the j pipe to the wastegate and it'll run what ever the gate is rated for. not quite what i would call a long term fix but it'll get you by till you get a boost controller.
Its just going to run off of your wastegate spring pressure if you do so as long as you have vacuum hooked up to it
Running off of waste gate pressure is perfectly acceptable as long as your waste gate is functioning properly. It'll likely build up to only about 7-9LBS, so you're fine.
Happy boosting.
