Driveline issues
zantrick
Mar 4, 2010
cleveland, Ohio
I am getting a teeth chattering sound from somewhere when I am power breaking or when the car is on very low throtle. I am also getting a sound that sounds like wheat a bad wheel bearing sounds like only when I am decelerating over 15 mph. I also get a clunk when I shift into drive from a stop sometimes. Any ideals? Also how can I check the transmission fluid level using some other means other then the dipstick because it sucks really bad. ^^ thanks guys.
It might be an axle. Jack your car up in the front and put it on jackstands. Then, grab your wheel and move it side to side, then in at the top and out at the bottom. Come back and let someone know if there was any play at all.
Sorry, then do same thing to back end of car.
