downpipe: ripped flex section = ok?
phlx
Dec 26, 2007
seattle, Washington
Stupid noob question.
I recently purchased a used RS*R? downpipe from XS Engineering and sadly when it got here i noticed that the flex section had a good... 1/2inch to 1inch size rip in the flex section. I realize with a used item there will be dings and such, but i wasn't sure how bad a ripped flex seciton is?
Any thoughts? Do i just take it to a muffler shop and ask them to examine it? Sorry for the stupid quesiton, i just wasn't ready for something like this yet hehe...
Thanks again for all the help everyone.
Yeah you should beable to just cut out the old flex section and weld a new flex peice in. Any local muffler shop should beable to do it for you if you done have access to a welder.
i was told the felx section is just like a cover over the piping? is this true? i would try to peek into the hole but didn't want to damage it furthur...
thanks for the info! now just to find a good shop near seattle! ;)
sorry, just wanted to clarify, so a riped flex section shouldn't have any adverse affects? mostly cosmetic?
A flex section is the "flexible" pipe on a exhaust which allows the motor to flex and not break the welds/nuts/bolts between the exhaust and motor. It does have a use because the fumes do flow through it.
oh weak... that's what i first thought when i saw it, but guy at XS said he thought it was in good shape so he didn't bring it up when i asked if things were ripped or not...
god i hope it's not too expensive. figured a used downpipe for 100 must be in good working condition :cry:
