Doors won't lock
Crazy91GSX
121
May 31, 2004
Lubbock, Texas
Hey guys... got a problem, hope you can help. The power door locks on my laser will not work. If you lock the doors from the passenger side, they will lock, and then unlock right after. And the drivers side lock doesn't even work. It is real stiff and you can't push it back to lock, it get's stuck. Just wondering if anyone else has had this problem before? Maybe lead me in the right direction to fix it?
Take off the drivers side door panel and look over the whole lock system. The drivers side lock is stuck open for some reason, and that cause the pass. side to unlock once you lock it. There's a whole shitload of pain-in-the-ass-to-work-with metal rods that make the locks work, one of them might be jammed up. Just look it over, I'm sure you'll find something.
