Door speakers dont work
webshell
61
Jun 23, 2004
SPringdlae, Maryland
My door speakers havent worked since i had the car. and the tweeters cut in and out. Im mainly concerned about the doors tho. i swap in new speakers but the wires arnt getting any power. Please help. Its no fun listening to 2 rear speakers.
did you check the harness to the back of the radio, try to stick some wires from a good speaker into the spots for the speaker outputs of the radio to see if the radio is bad.
Defiant said:
Kind of hard to throw answers at. Pull the door panels, pull the radio, and have at the wiring with a continuity checker. :confused:
checking continuity won't help if a wire has been cut into, cracked, frayed and only a few strands are left. then it won't be able to deliver the power. start at the source the radio, then go from there finding where the signal is lost
