diab0liK
- 133
- 1
- Feb 17, 2005
Ann Arbor,
Michigan
Ok.
This is a very interesting problem I've run into...
First of all, I haven't had a license for awhile, had a "situation" that I got reduced to a reckless driving, 3 month suspension with no possibility for a restricted, so my car has been sitting most of the summer, with an occasional drive to the store for cigarettes or something.
Just got my license back monday.
Beside mechanical issues with my car, I've encountered this one, which could prove to be a serious bi***.
Ever since I bought this GS (last 420a I will ever buy...i hate this pile
), I've had nothing but issues. When I bought it, the driver side door had been replaced, with a talon one, and nobody ever bothered to put a new barrel in, so the driver side has no locks. Car has power locks, so I can just go unlock it on the passenger side, and it opens both doors, I've been doing this for awhile (since all my money got sapped into lawyer bills and court fees, etc., haven't bothered to fix it yet). The car has been sitting most of the summer, and when I went up to my parents house to pick it up over the weekend, I was sorely greeted. I was up there a week or so ago to clean it out, and there was no problems.
However when I went to pick it up, a squirrel had decided to use my engine bay as an acorn storage center. Cleaned all that out, only to find out that he had put a bunch up by the blower too..haven't gotten around to pulling that yet.....
I opened the passenger side door (wouldn't open from the outside, so I opened from the inside), and then when I went to close it, it wouldn't latch. So I locked the door, and it closed and latched, and I didn't think of it again.
When I got back downstate, I go to open the door again, and nothing. So then I try to open from the inside...nothing. I proceeded to try to unlock it manually....nothing. It only unlocks like halfway, and then sticks. Fortunately, I can still unlock from the outside via the autolocks, but even the key doesn't turn all the way on the outside, just enough to trigger the auto locks.
I am really at a loss here.....I can't get the door panel off, because all the screws are hiding behind the frame, and since I can't get it open, it's not good.
Furthermore, I need to replace the positive battery lead, b/c it's a cheapo thin ass aluminum one, and it's as tight as it can go, but can now be easily pulled off. I'm really, really broke for a couple weeks, but I'm afriad it's going to pop off, or get a bad connection, and then I'm not going to be able to open the car, and/or pop the hood to get a good connection, so I have to pop the hood everytime when I close the door, just to be safe.
Anyway, I've tried pulling the handle while pulling the manual lock, from the inside, and outside, pulling the lock while hitting the power lock, etc. etc.
The lock is still pulling the actuator, but it just gets stuck haflway, regardless.
I sprayed as much wd40 into the crack of the door, by the latch from the inside, and outside earlier, but to no avail so far.
If anyone has any ideas, I'm willing to try it at this point, because pretty soon I'm just going to break out the cutting wheel and rape the door panel, and figure out what's wrong.
I did a ton of searches, and can't find anything on the topic, so if anyone can even come up with a link, that would be great.
Thanks in advance,
diab0liK
Oh, also if anyone has any diagrams of a 2g door, with the interior panel removed, that would be helpful, or a diagram of the lock system would be incredibly helpful....I rolled down the window and looked in there, the door handle on the outside is still pushing in, and the handle and lock on the inside are still pulling....the lock is just jammed, apparently.
), I've had nothing but issues. When I bought it, the driver side door had been replaced, with a talon one, and nobody ever bothered to put a new barrel in, so the driver side has no locks. Car has power locks, so I can just go unlock it on the passenger side, and it opens both doors, I've been doing this for awhile (since all my money got sapped into lawyer bills and court fees, etc., haven't bothered to fix it yet). The car has been sitting most of the summer, and when I went up to my parents house to pick it up over the weekend, I was sorely greeted. I was up there a week or so ago to clean it out, and there was no problems. However when I went to pick it up, a squirrel had decided to use my engine bay as an acorn storage center. Cleaned all that out, only to find out that he had put a bunch up by the blower too..haven't gotten around to pulling that yet.....
Thanks in advance,
diab0liK
