Does size really matter...[exhaust piping vs smog test]
TurBoGs-T
2,671
Sep 1, 2002
Glen Burnie / Balt,
My ? is does Exhaust size really matter when doing emissions testing??? I failed my test the other day. I thought i had the stock system on there but i don't know what the heck the previous owner did. Looks like he has a 3inch dp eliminator and stock catback.:confused: Anyway if i just put on a full 3inch exhaust with the cat.conv. will that still pass emissions or is 3inch automatic fail due to size???
I have to have the stock cat on there??? i can't do a 3inch system with the stock cat. I can't just put a 3 inch cat on there and pass???
Originally posted by doug
The catalytic converter does not have to be "stock" in order to pass emissions. Yes, a 3" high-flow cat should be just fine.
That was like music to my ears!!!!! Thanks
I would have thought that too, but he did fail emissions with is.
I'm almost sure you do. They don't look for one under the car but the test can read if you have one or not.
A week after I installed my thermal cat back I had to have my car emission tested. At that point I still had a stock down pipe and cat. the car passed. However the awd treadmill was broke. I hope its broke again because I have to now have a 3" converted welded in to pass emissions next month:mad:
Originally posted by Herbal Essences
Well, if you dont have a cat, that is probably why you failed emissions.
:confused: Lol. I already knew that.
My ? was is would a 3inch system with a cat pass.
I passed last time with a 3" downpipe, 3" high flow cat, and 3" cat back. So you should be OK. As long as the emissions are all with in spec.
:thumb: Great now i have an excuse to buy my 3 inch system. plus if i spend more than $450 i automatically pass.
Yes, i have a 3 in system and passed MD inspection. Just make sure your emissions are good. A true 3 inch all the way with a cat. is good to pass. I just had to lean the piss out of my car and take it on an ITALIAN TUNEUP
