does higher rear end mean less understeer?
OnABudget
42
Jul 21, 2004
Bay Area, California
ive heard people with coilovers can set their cars up so that the rear is higher then the fronts for less understeer. i have eibach prokits and was thinkling of keeping the stockers in the rear with the 1" drop in the front. has anyone tried this? what were the results?
ps: for my awd and also with adjustable shocks
please dont tell me to buy coilovers
thanks
i found the spring rates of eibach rears to be 160 lbs/inch and stock to be 140lbs/inch. considering that isnt a significant difference (is it?), wouldnt having the rear end higher help me out to get rid of (some/most) understeer?
Correct - raising the rear will increase the roll axis inclination which will make the car looser.
You can put stock front springs in the rear, but the front needs to come up a good inch to allow the 330lb ProKit fronts to function without constantly bottoming. Until the front gets either much stiffer or much higher you're flogging a dead horse.
Charles
you mean stock rear springs in the rear, right?
do you think that the eibachs arent stiff enough for that? the fronts are still a lot stiffer than the stock fronts-
No, I mean stock front springs in the rear. It's only a 250lb spring, it's just taller. The ProKit fronts are ~330lbs, the rears ~160lbs - that's not much at all. The fronts are less than 30%, and that's from a woefull soft spring to start with.
To run at the ProKit ride height the fronts need to be about 500lbs, which means the rears need to be at least 350lbs. That's why ProKit'ed cars bounce on their bumpstops all the time
thanks for the help, but you cant put front springs in the rear?
They've worked fine on my winter suspension setup for a while now.
  • For sale 2g 2GB Eclipse Reverse Lights ( with bulb sockets )
    2GB Eclipse Reverse Lights ( with bulb sockets ) $35 + shipping & paypal feesYou must be...
  • For sale 2g Tan Sun Visor Set ( with home button & hardware )
    2G Tan Sun Visor Set $50 + shipping & paypal fees* home button * hardware includedYou must...
  • For sale 2g 2G Black Ashtray/Cup Holder
    2G Black Ashtray/Cup Holder $35 + shipping & paypal fees* both sides open and close as they...
  • For sale 2g 2G OEM Radio Brackets
    2G OEM Radio Brackets $35 + shipping & paypal feesYou must be registered to see element.
  • For sale 420A 420a Miscellaneous Parts
    Hey Guys I have a 420a car that just came in, if you’re looking for any miscellaneous engine bay...
