Does anyone have the APEXi power FC or know anything about it?
what do you want to know?
PS- why make a post like this? Why not just ask the question and eliminate the need for a reply like mine :confused:
Why would you ever want one? You have a 95 AWD, which means you have an EPROM ECU most likely for a DSMLink.
PowerFC is good, but DSMLink is better due to its total integration of the factory ECU.
Could you explain this for me a little further? Maybe, there is a link or a site or something I can check out more info on it? What it is? How it works? Etc?
What brought this whole thing to surface was that I wanted an apexi BOV. I was told not to get one because they vent to the air. Then I called apexi to see if they had a recirc kit of some sort and the guy told me about the power FC and how that would eliminate all my problems. Never have heard of it, I started this thread.
I have no idea what dsmlink or an eprom ecu is......... Will someone help me further?
power fc is a stand alone engine management system, it replaces your stock ecu, it uses all the stock sensors and stock wiring harness, it comes with a base map to work with a unmodified car, it can adjust fuel and ignition with a 20x20 map. It has a ton of features, it's the simplest plug and play replacement ecu system, pull it out of the box plug it it and start the car. It has a optional power fc commander unit that is a handheld so you can adjust everything in cockpit.
I doubt you want to use it to vent a bov to athmosphere. It's about $1500 with the hand controller. I used it on my 240sx with a SR20DET.
