Does 92-94 Eclipse tail lights fit the 90-91 Eclipse?
They will fit if you change the bumper as well. As for straight bolt on, no.
Look at the difference between the center sections, 90-91 is straight across and the license plate bolts onto the bumper. The 92-94 has a dip in the bumper and the license plate bolts on right by the tail lights.
Ok if you get the tail lights off of an eclipse it will bolt on without a problem. Its only the 92-94 talon tail lights that have that problem. :thumb:
