Do oil squirters fit with 6-bolt 2.3 stroker?
steel_3d
494
14
Jul 3, 2003
LA, California
Will Eagle rods hit my squirters? I'm aware of other clearance issues.
No, My oil squirters are in and do not hit anything. I have a Wiseco/Eagle setup. The only clearance problem I had was the #3 rod was rubbing/catching on the inside casting lip of the block about where the balance shaft would run. A quick minute with a die grinder solved the problem. Look in my thread for some pics of what I mean.
http://dsmtuners.com/forums/showthread.php?t=208602&page=3
