different boost readings in each gear, ???
cfisher
451
4
Dec 21, 2002
olathe, Kansas
don't know what to think. have a tial 38mm external wg/external dump so i should not be having boost creep. 3" turboback/no cat/. WTF is going on.
1st gear (20psi)
2nd gear (18psi)
3rd,4th,5th gear (16psi)
i would like to push 18psi in all gears.
i also have a MBC installed. could it be this or am i looking in the wrong place.
anyone out there that knows, please help me out on this one.
What kind of BC do you have? Some of the bleeder type will do that. If youhave a ball and spring I would look for leaks in the vacuum hoses to see if that could be causing it to get a weak signal.
it's a ball/spring. i've gone through all my lines and cannot find a leak anywhere. i'm wondering if it's my egr blockoff.
i've got a ss tubular manifold so i know it's not that. will an exhaust leak anywhere cause that though.
still no solution. i went through all my vac lines, egr blockoff is good, manifold is perfect, no exhaust leaks. i'm stumped. i can only think my MBC is screwed. any other suggestions.
